Winch removal
aadewar
Winch removal
Inlägg av aadewar »
Hello, we are going to replace our winches with Anderson bottom handle winches-but..
How hard is access to the mounting? It looks like there is no way to get to the underside of the base. Is it through-bolted?
Thanks!
Aaron
Re: Winch removal
The plates of the winches are simply fastened from above by wooden screws. You will get access by dismounting the mechanics of the winch. Then use a large screwdriver... 8)
aadewar
Re: Winch removal
Inlägg av aadewar »
Thank you, I shall sleep easier!
